re: nsport turbo kit
Mameluke
to the guys who got the kit. if u get the stage 1 kit, can you install it with stock internals reliably? or is it recomended that you get a rebuild first, etc
Mikel
For any turbo, it depends on the condition of the motor. I would do a compression and leakdown test. If they come out fine, odds are the motor will handle it easily, regardless of miles.
95_240sx
Car: My baby (car)
Boost it till it blows.
No serisouly, with proper tuning a good stock bottom end will hold up quite well, as long as you take car of the car and keep it in tune.
Rick
silviaNE
Car: cars what else?
proper fuel and ignition is key. With that you can take a stock engine pretty far.
Structure240sx
i have 119,9xx miles on my KA. i did a leakdown test and the motor is still strong from what my cousin says that ahs hundreds of rebuild under his belt. he does 454 marine engines mostly now makeing about 1000hp
Mameluke
thanks for the infobtw my motor has 170k, say it doesnt do so well on the tests.?
Structure240sx
do u have a second car to drive around? if u do then **** it turbo it and see what happens. u could alwasy find a low milage KA to put in for around $500.
SHiFT
Structure240sx wrote:do u have a second car to drive around? if u do then **** it turbo it and see what happens. u could alwasy find a low milage KA to put in for around $500.
yeah you could do what he said or get a SR or something. I dunno, 170K seems pretty high to start boosting. I'm not all gung ho about SRs anymore, but it would set you back to 30 or 40K miles again. The nsport turbo kit is around 4 grand or so and I hear it takes months to actually receive it, BUT its the best one out there you can find from what I've read (240 rwhp!). For that price you could have a SR purchased and installed, but thats with little to no mods. The turbo KA would be a lot faster, but then again you wouldn't be going anywhere if the engine couldn't handle it:rolleyes .
Mameluke
im gona go do hte leak and compresion tests. but even if i pass, i coud still strengthen my bottom end, where can i get forged pistons/rods etc with stock specs?
and just in case can someone let me know where i can get a low mileage kade motor too
SHiFT
that sounds good. If you have the money to build up the bottom end then by all means go for it, your car will be madd quick by the time you've got everything in there. I'm not sure where you can get those internals. As far as getting a new KA, just post a WTB thread and you'll get replies. Lots of guys swapping SRs have their KAs lying around that they'd love to sell cheap.
WDRacing
I have an idea for ya...basically what I did when I started boosting Skylines. Since you know your gonna buy a turbo kit with or without the built engine. Your also gonna have to buy a fuel system and what not to support the turbine kit. All of which are swappable if the engine goes tits up. So install the parts on your current machine and tune it up. If you make any mistakes and blow up the motor. Drive down to the junkyard and buy a new DE for a few hundred bucks. The upside to this is that motors make mad power when you run them really lean. Like just before they pop...heh. I went through alot of RB's that way. But it sure was fun. Oh, but I get them for 150 bucks...heh...just had to rub that in a little.
WD
slipsr20
here you go! check out Davee's car! Looks great and looks fast! (Its an nsport.)the link:http://www.nissaninfiniticlub....ber=1
TomsMR2
Car: cars.. etc
the nsport is overpriced.. its just a turbo, manifold, intercooler, and FMU. intercoolers dont really go bad, as long as they visually check out, you can save TONS by getting a used one. manifolds are cheap, get a jgs one. you can piece it together yourself for 2K...
bruinbear714
TomsMR2 wrote:the nsport is overpriced.. its just a turbo, manifold, intercooler, and FMU. intercoolers dont really go bad, as long as they visually check out, you can save TONS by getting a used one. manifolds are cheap, get a jgs one. you can piece it together yourself for 2K...
That's what everyone would love to be able to do, but unfortunately that's not always the case. You can fork out the $4,000, install it and be done with it. Or spend $2,000 plus all the time researching, gathering parts, fabricating parts, headaches, and be proud that you pieced together your own kit.
If I had a project car, I'd do the latter. But for my daily driver, I'd rather just buy the $4,000 kit, slap it on, and call it a day.
Accelerated Concepts
Car: Nissan Cars
Yeah, too bad the Nsport kit doesn't cost $4000 when you buy it from us. We sell them at $3495.
JayPat83
UH in ATL $5200: custom T3/T4 Garrett turbo w/ external wastgate, custom manifold, 34in. FMIC, 91 exhaust cam, 370 injectors, ACT clucth, Blitz SS bov, downpipe, intercooler piping, Apex-i S-AFC, boost oil EGT and a/f gauges, turbo timer, "A" pillar 2 gauge pod, custom 94-98 mustang 2 gauge dash pod, egr crap removal, battery relocation kit, valve cover painted to match intercooler piping anthracite gray, everything installed and tuned to perfection, still getting over 400 miles per tank no matter how hard i run it. Running daily on 7-7.5 psi getting 250-260 to the wheels. Also free UH window banner. Ran out of money or would of had them do much more. When i get more money they will do more.
TurboKA37
not bad, I would definatley get something like that all custom done in a shop like u but there are no shops around here that would have the knowledge to peice all that up. O well guess that means im goin for a kit sometime soon.
JayPat83
i am sure they would be happy to strike up a deal with you. look them up at http://www.unstable-hybrids.com
SHiFT
JayPat83 wrote:still getting over 400 miles per tank no matter how hard i run it.
how in the world do you get 400 miles per tank?? This is a 240? I think everyone else here gets 270-290 by fill up time. Do you mean 300? If that is the right number tell us your secret!
JayPat83
why are 400 per tank so hard to believe? im talking like 400 wether its at 80 mph with the a/c on or driving just around town. everyone i know around here with a 240 and also in ATL all get around 360-400 easliy. one time on a trip to ATL i filled up before i left and didn't get gas agian until i got home. i was sort of cuttin it close but i made it and i think its like 220+ miles each way. i have a 95 S14, 5 speed, nothing done to increase fuel mileage.
huguetpj
Car: 93 KAT Coupe
Holy c... I'm only gettign about 240-250 miles per tank... crappy third world streets... :pface crappy third world gas...
But 400 miles!!!! That's quite a bit... maybe you should recheck your numbers... hmmm... jeje
bruinbear714
Last time I checked, I got 330 miles a tank with 1/2 highway driving, half city driving. This is in So Cal, the only place where it takes you 2 hrs to drive 5 miles.
JayPat83
no, i am getting around 360-400 miles on 14-15 gallons of 93 octane.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
that's 25.7-26.6 MPG...that's really not that incredible i think...
isnt factory rating like 26?
