Projex240 wrote:Same way you increase pressure on a BOV thats design like the turbo xs RFL. Putting shims in it makes it stiffer-----viagra for springs.
Scotty---fo shizzle dizzle, thizanks fo' the phiznat hizzelp yizzo.Ive been trying to get my buddy to get those cam gears. He has the JWT cams in his built KA, and recently did a compression test.The numbers were really low. 128-130-128-128I thought it was because of the large overlap on the cams--JWT doesnt even know. I called brian crower at crowere cams and we talked. He told me that the overlap will cause low compression, but too have it that low--the JWT must have ALOT of overlap. The cam gears are the only way to remove the overlap by retarding the intake, and adving the exhaust. However, they look like, and I have been told, they are a bizznitch to install and work with.Any comments? Have you comp tested your motor yet? Do you have unusually low numbers? 8.5:1 is lke 160-ish---128 is just way too low.
Projex240: Installing the cam gears is no big deal if you know how to install the timing chain. You only have to remove the top of the chain to install and adjust. The only drawback is that the valve cover must be removed, the top of the timing chain removed and the cam bolts as well to re-adjust. But really, I had no intention of any re-adjustments ... just the initial retard/advance to compensate for the larger cam profiles. Worked like a charm and I highly recommend them to those doing performance cam swaps, especially for turbo
. And no, I haven't done a compression test yet ... will do at the dyno (whenever that occurs)
WDRAcing: The whole "fizzle ma nizzle yaz tenzzle centzzle crackzzle *****zzle" drives me insane as I have no freakin' idea what any of that means ... but I do think it's dope, YO! Oh, and thanks for giving up my secrets ... I'll get you my pretty ... AND YOU'RE LITTLE DAWG TOO! :ylsuper
