RE: Electrical Problems!! need help!!
240sr20_89
Car: 1989 Nissan 240sx
Ok! so i got the car home. had to boost it 4 times to get it home haha and 1 1/2 trip turned into a 2 1/2 hr trip. anyways! i got the car home, pull it into the garage and was lookign at the engine area, i oull the battery out put it on a charger, and the battery is fine! thanks god. and i looked over the wires to the fuse box behind the battery and to the alt. and they look ok but i'm going to take a deeper look. i out the battery back in hooked it all back up the battery read 11.88V and so i started the car and it dropped to 11.56V it DIDNT jump to 14.30V like it should have. i tested the altenator and i tested what i think is the main output for the altenator and it read 0.35V?? which i've never incountered before. i havent tested the connector on the side of the alt. yet or the other connection on the back.
Also i'm still haveing the same Aux. power issues as last time. when i start the car nothing turns on xcept the blower motor and occasionally the headlights. as soon as the car hit 2500RPM everything turns on, the wipers the signallights(emerg. also) and the whole gauge cluster (all gauges) and tehn they stay on untill i go shut the car off and wait about 20 mins then the car wont start i boost then start the car nothing turns on until 2500RPM.
Sorry if it seems like i'm rambling on. try to give as much detail as possible
also about 4-5mins before the car dies i smell an ammonia smell coming from the vents coming from the motor?? please help! i'm stuck on this Thanks!
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Did you ever get the alternator tested?That sounds like your problem.
240sr20_89
wel
sx moneypit wrote:Did you ever get the alternator tested?That sounds like your problem.
Well apparently the alt. is almost "brand new" i know the battery brand new cuz it still has 3 year warenty so its only like 3 weeks old. so anyways i'm still gonna get the alt. tested at the shop. but why would what think is the main output from the alt. read 0.35V?? is that a normal reading? or is it possibly toast? just to give me an idea of what i'm dealing with.
sx moneypit
1986 Toyota MR2
With the car off it should have battery voltage. Check your fuse links.
240sr20_89
sx moneypit wrote:With the car off it should have battery voltage. Check your fuse links.
Hey! yeah you were right! thank you for telling me to check my fuse links. turns out it was a blown alt. fuse that was screwing everything up. I'm so happy now i can drive my car again :D Thanks again!
93inHOU
Car: 1993 240SX SE Coupe
SX Moneypit, do you know where the Altenator fuse is located that was blown in this thread?
sx moneypit
1986 Toyota MR2
It is located in the underhood fuse and relay box.
93inHOU
Found it, thanks. Unfortunately it wasn't something simple like a blown fuse for me. For some reason all of my running/parking lights will not come on. I have checked all the fuses and they all look good, so I will keep investigating.
