Re: (DominickJ30)
cortheal
Car: infinity j30 93
"AT" check on the dash board means????
and if my timing belt broke am i screwed or what?
cortheal
hi and thanks......well i drove the car home and came back out in like two hours.....and it wouldnt start my mechanic dude listened to it and said was the timing.......if i wasnt driving it when it happend am i to believe i may be ok......i mean i drove and parked it and the n two hoursd later.....no start!
damn!
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
(AT) is automatic transmission check light
driverdriver
Car: NICO's longtime resident Canuck!!!
cortheal wrote:and if my timing belt broke am i screwed or what?
Yeah, if your timing belt breaks while driving, you better pony up some major cash for a new engine. Its best to getthe belt changed ASAP!!!
Defiant
Car: 1997 J30
cortheal wrote:hi and thanks......well i drove the car home and came back out in like two hours.....and it wouldnt start my mechanic dude listened to it and said was the timing.......if i wasnt driving it when it happend am i to believe i may be ok......i mean i drove and parked it and the n two hoursd later.....no start!
Startup and idle are the two most likely situations for timing belt failure, as it is when the stress is greatest on it. No-start is often bent valves- the starter motor has enough power to cause damage. I'm a bit concerned what part he "listened" to for his diagnosis. If it involved cranking the engine over, and you do have belt damage (usually teeth sawn-off by the crank sprocket), more damage may have been done.
