DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Wed Oct 22, 2003 12:19 pm
Don't do a $35 conversion unless you're OK with your system failing within a year. The 2 don't mix. You'll have to flush the system to do it right, replace all the seals, all the rubber hoses, and maybe even the compressor if it's not designed for R-134a. It is cheaper to keep it stock R-12, even if you have to fix a leak or 2. As far as DIY, I don't remember if it's legal to do it yourself, but if it is, then you could just add half a can at a time till it stops getting better. It is definitely not legal to vent any refrigerants. Note that if there's anything wrong with your system other than low R-12, you'll just be wasting the stuff you have.
Add a proportionate amount of oil based on how much R-12 you have to add. Not the most precise way, but if you're set on DIY...
