re built ka 24 e starting promlems
single cam slider
Car: 1990 240sx
well im new to nico club so not to sure how this works but i just bought a shell that used to have an sr in it then i got a free single cam re built it hooked everything up its in the car it cranks and it has spark and fuel but just wont start we timed it at least twenty times and its right on the only things i can think it could be is vaccume lines and that it has realy old gas in it lol any suggestions?
BearTrap
Car: '90 Hatch Bored, Ported, and Cammed
Compression?
Klits562
Car: white s13 coupe
mhmm compression test italso check any known vacuum lines(idk how much you know about 240s)make sure the injectors are actually working and make sure you actually are getting spark.
single cam slider
Car: 1990 240sx
i compression tested it and it was right around 150 and i got a diognostic test and it just came up with a code 55 i also checked for spark buy grounding a plug out on the block and it sparked and the spark plugs smelled like gas so im guessing the injectors are working so i dont know
single cam slider
Car: 1990 240sx
