ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Wed Jan 10, 2007 1:36 pm
The actual parts cost is very little for a rebuild. Bearins are pretty cheap. Rings are 100 for a set, full gasket set is another 200 or so.
If you need any additional machine work... it starts to climb. Polishing crank journals cost about 50 bucks. Grinding them down cost more. Honing cyl walls is around 50 bucks as well.
If you want someone to assemble the block for you, it will be even more money. This is where it starts to add up alot. Labor is the killer.
Buy all the parts you need, get the necessary machine work done and assemble it your self. This is the most cost effective way of rebuilding. Rebuilding an engine is not so hard. You need proper tools like a quality torque wrench, angle gauge for torque-to-yield bolts, piston ring compressor, installer, etc. You also need a plastigauge to check for clearances. Also might benefit from a feeler gauge. Both very cheap and easy to use.
