AZ89two4Tsx »
https://forums.nicoclub.com/az89two4tsx-u91596.html
Mon Jun 07, 2010 10:22 pm
Get all the lines from a junkyard. Also, the blower, HVAC unit, compressor bracket, condenser, and vent plumbing if it's not already in the car.
IMPORTANT - Get a brand new compressor from the autoparts store. Do NOT get a used one, you will regret it. Also, get a new dryer as the compressor warranty will be voided if you don't.
Buy a new o-ring kit from Nissan and also decide if you want to convert to R134a.
Expect to spend $500 - $1000 to get it working RIGHT, even doing a lot by yourself. The system will need to be completely air tight which is very hard to do, especially with used parts as some of the lines may be warped and especially the blocks that attach to the compressor.
I don't know where you live, but if you're in AZ I have a brand new condensor, and if you're car is a sohc, a compressor bracket.
