RC injectors
Rambo24o
Car: S13 240sx
I am going to put some RC 370 injectors on my CA, i want to go back to stock the CA is runninh 660cc . How do i add a resistor box? 0r
what should I do?
"RC 370cc high Resistance injectors"
float_6969
What? So confused. What is in there now, low impedance, or high?
Rambo24o
Car: S13 240sx
I have some high impendace 370cc
Can i add a dsm high impendace box where the stock one goes?
I want to do this find a stock resistor box plug and just wire it to the dsm box and conected to the stock harness or would this not work?
float_6969
The stock setup is low impedance. If you have high impedance in there now, the stock resistor box had to have been removed for it to run. If you're wanting to go back to low impedance, then yes, you can add the resistor box from a DSM back into the harness and run low impedance injectors.
Rambo24o
Car: S13 240sx
Well yes but back words i have low impendece and want to go high cuz my RC injectors are high impedance
Rambo24o
Car: S13 240sx
Ok i think i get what ur telling me just take my resistor box out n run it like that???
float_6969
yes. But I'll bet it runs like s***. You're going to have to modify the dwell map in the ECU to get the injectors to fire properly.
