WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Sun May 02, 2004 5:06 pm
The 3.0 should fit fine under the hood, I would think. Or I'm sure can be made to fit, such is the nature of our hobby.
The 3.4 stroker/bore kit would work, you'd have to have a custom crank ground and the cylinders punched out a ton. I'm not sure of the stock RB30 stroke though, I think she's already got quite the long stroke. So more would yield more torque but kil your revibility. If it was an option I was doing, I'd look into sleeving the block for strength though.
Expensive to say the least, a better option in my mind would be to have a stock crank reground and lightened and balance with the entire rotating assembly. Using the lightest internals one can find or have made. Titanium rods if you can afford them. Then beef up the valvatrain and get a set of bigf cams, like 280 or better with increased lift. Then extend your rpm range for more power. Your on boost window will be longer and your numbers will be greater.
But thats juts my .02
