i have a greddy front facing plenum. front mount intercooler.bov.38mm wastegate.headers.3 inch exhaust.custom td06 25g turbo w/ 4 inch intake.
cars a r32 running r32 ecu (chipped --- was chipped for 20det
the problem is its strong to drive..lots of torque..drives fine off boost (at 0 or under on boost gauge) but as soon as it starts to get any boost (only have 5psi spring atm) it just falls flat on its face... it has no trouble making boost pressure .. but it actually goes slower on boost than it does off boost
is running red side fed injectors
i am wanting to get purple rb25 injectors and a rb25det ecu just to get it running so it can actually boost
it feels like its retarding timing or something to loose all power
any ideas if i need to fix something ??
the plans are to at the end of it have some large injectors (750cc or bigger) and a road tuned ecu map and a z32 afm... but as for now i just want it to be able to boost even if only 8psi !!
if anyone needs any more info just ask and i appreciate feed back !!!
