rb30det hyrid vs a rb28det
REDLN
Car: 95 Nissan 240SX SE
yeap tried jhot already. Mckenny,venus,enjukracing, draginter ... No one sales them individualy. anyone have one for sale
stiergott
Car: 240
BoostsFed wrote:although the sr and the rb30 has a close stroke lenght...as far as using the sr rods and pistons...that is unknown territory....
all you have to do is get the sr rod around the rb30 crank and the rest is gravy. if you have to bore out the block slightly to get the piston in there so be it, if you have to machine the inside of the block so the rods dont slap the block walls thats ok too. course the hard part is getting the rods around the crank...
BoostFab
Car: S13cp, S13fb, S14z
stiergott wrote:all you have to do is get the sr rod around the rb30 crank and the rest is gravy. if you have to bore out the block slightly to get the piston in there so be it, if you have to machine the inside of the block so the rods dont slap the block walls thats ok too. course the hard part is getting the rods around the crank...
why do you want to go through all that hassle when there already rods and pistons off the shelf for the RB30!!!! i dont understand ppl these days?!?
ISL33P
Car: VH45DETT powered
they try to do it the cheap where way where in the end it ends up costing double.
"do it once and do it properly"
stiergott
Car: 240
to the first guy, tell me where in the US i can buy rb30 rods. i know of a few places in australia, but they are in australia. besides, if the rb and sr rods are the same why cant i use sr rods.
to the second guy, so its better that i go out and use chevy or toyota rods in a nissan motor? if the sr rods are within tolerance then they will work, they are closer to the factory rb rods than the chevy or toyota would be, the fact they are cheap has nothing to do with it. if i buy pauter sr rods its gonna cost more than $1200, cause i will have to buy 2 sets. if i buy the chevy rods, 1 set at $400 shipped. personally i think its stupid that someone pay for rods to be shipped from australia or japan when there are prefectly good alternatives here in the states.
