RB30 Q&A
REDLN
Car: 95 Nissan 240SX SE
maybe and i hope your right. What rods are you using?
Stealth-Z
Car: 1991 300ZX
Spool Rods.
Sent you an email earlier. Lots of info in it.
REDLN
thanks for the email mate. lots of good info there too. yeah we need a sticky too!! please
Chaos the Xile
Car: 1974 Datsun 260Z
Hey Stealth Z! can u shoot that email this way too? [email protected] Thanx man.
ISL33P
Car: VH45DETT powered
same rods that i have arriving soon. just trying to figure out what pistons/compression ration etc.
Stealth-Z
Car: 1991 300ZX
Piston / CR has been one of my confusion areas of the RB30 build. From information gathered, the key is to initialyassemble the crank, rods and pistons, then measure the piston height. A professional machinist will know how to do this.
Using the flat top Wiseco pistons, a CR range of 7.9 to 9.3 can be obtained through a combination of decking the block, surfacing the head, and head gasket thickness. Up to 1mm can be taken off the head safely while the block can have up to 1.5mm.
ISL33P
yeh going to talk to a local engine builder and see what he says
i like the idea of 9.0:1 with a t51r :D
Chaos the Xile
Stealth - Z thanks for that email man, mos definatly. Raise your hands if you want a sticky!~
REDLN
that's a nice shinny rod piston combo you got there mate. it'll be a while before i get some of those.
GTR Shop
Car: 180sx RB26 T78, Y31 Gloria VIP + HEAPS of GTRs!
If you use a GTR PFC you're going to run into issues using 1 AFM on a single turbo setup.GOing to have to try and fit 2AFM in or go to a D-Jetro.D-Jetro works, but you have to know what you're doign tio get them setup correctly.
Stealth-Z
Car: 1991 300ZX
Thought it would be nice to keep this post going a bit. These are Vid's of a RB30DET in action. It is in a R31 Skyline owned by Skylines Australia member StockyMcStock. Since Australia measures speed in Kilometers, divide his numbers by 1.6. 140KPH would be about 88MPH.
http://www.youtube.com/watch?v=N1IP_x_X ... PghQq26gKs
REDLN
man that sound nice! i can't wait to get mine.
projeks13
Car: 89' 240sx coupe
sticky sticky! so's ppl dont have to waste space by asking random questions about a little known swap!
Chaos the Xile
I keeep saying the same thing. STICKY! Soon this will be a sticky when more and more swaps become plentiful. Nice work on the 30! Massive torque I see. In that one vid you can see the car kick out before the camera boggs down!!!
DanCouga
Car: 1997 Nissan 240sx
Why not just append information to the RB20DET vs RB25DET vs RB26DETT FAQ? It makes more sense.
DanCouga
So when I first entertained the idea of doing this, I had a bookmark for a billet crank girdle from a shop in NZ. At some point in time, I lost my favorites. Does anyone know the shop that makes it?
Also, does anyone have information on any RBs running dry sumps? Does anyone know of a dry sump pan available already? How close is the L6 family in regards to the RB? It's a long shot, but I have found plenty of dry sump systems available for them and it would save a nice chunk rather than having a custom one milled.
GTR Shop
The RB30 girdle is almost IDENTAIL to that found in any of the turbo RBs.Why go to a 1 billet one that would require the std one to be machine up into individual caps??
Dry sumps.. as long as you always have oil at your pickup.. not needed. Few ways around this
DanCouga
I'm not going to question you on the crank girdle. When I first started researching this project, I had read that RB30s crank girdle and block were slightly weaker and that the billet girdle increased block rigidity. Of course, all of that information came from the manufacturer of the girdle, so they could have been slightly biased.
As for the dry sump vs. wet sump, I would prefer to go dry sump for a few reasons. It would give me the ability to drop the motor farther down to compensate for the 30s taller block. While most sloshing, starvation and churning can be "solved" in a wet sump system, I would prefer to protect my investment and just use a dry sump.
Also, you need to e-mail me back
REDLN
all most lost this so for a bump i ask how much tall is the rb30 then the others? I need this in a sticky so i can always find this.
Eikon
Car: 71 240z, 93 Supra TT
This is a great thread you guys!
Too many stickies tend to make forums stale and less intereresting. But this thread should be easy to find.
I edited the RB20 vs RB25 vs RB26 sticky to include a very short description of the RB30 with a link to this thread.
If you guys want... flush out Pro's and Con's of the RB30 to mirror the other engines, and I can add those as well. zer...77883
DanCouga
REDLN wrote:how much tall is the rb30 then the others?
I have read everything from 20mm to 38mm. I don't have a 20/25/26 block, but when I get home tonight I can measure the 30 block for you.
DanCouga
Since this thread is quasi-stickied now, I will go ahead and add useful tidbits as I think of them. First being the DOHC RB30 PDF.
REDLN
sweet write up you found and posted!!!! So much there that i didn't know. Well the little thing that some don't talk about.
