themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Fri Jul 01, 2005 2:41 am
the cool thing about the RB30 is the long rods. I read in a book by Smokey Yunick that long rod motors tend to build compression at high RPM making it a perfect NA motor for sustained full throttle. I would love to do a GTS-4 with a high compression RB30 and sports injection bodies. It would basically be a modern L stroker.
:::::::::::::::Update, mad needs coffee::::::::::::::::::I almost had it, it's been a while. It's that the piston dwells at on or near TDC longer with longer rods allowing power to be applied to the crank longer increasing torque. That's what I was trying to remember. Short rod motors accelerate from TDC faster so the torque drops off. Imagine pushing on someone who is walking in front of you and pushing someone who is running away from you, who can you push harder and longer? This also gives the valves more time to fill and exhuast the cylinder, more air needs more fuel and you get more power and less contamination from lingering byproducts of the last explosion.It also reduces the rod angle from crank to piston pin (the rod is at less of a cocked angle) this reduces piston side-loading and cylinder wear. This more linear angle to the crank also allows the rod to transfer energy more efficiently.
No wonder I wanted that engine!
