rb30 build question
67 411
Car: 1967 datsun 411 sss wagon 1975 datsun 620 king cab 4x4 and a 1971 521
i have read on here that to build the rb30 you need a head without vvt is that true?has anyone used a rb25det head?hoe good is the bottom end in the rb30?i have heard they are almost bulletproof sorry if these are stupid questions
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
You definately have a lot of searching to do.
Yes, you can use a RB25DET head and retain VVT. There is a modification needed to get oil supply to the VVT, but it's very easy. It's outlined in the RB30DET section of Skylines Australia.
The RB30 bottom end is very durable, no worries there. I changed pistons to forged to get the compression ratio I wanted, but the rods and crank can take way more than you'd ever throw at it.
Read EVERYTHING in this RB30 section if you are serious. It answers any question you would ever have.http://www.skylinesaustralia.c....html
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
Where did you pick up the rb30 bottom end at? I was looking at putting 26 crank in rods in my block. but instead im looking at spending the money on the 30. After it was all said a done was it worth it honestly?
67 411
i havnt purchased one yet but im trying to find out if its worth it to find a block and pay alotta $$$$ for it or if its better to build a rb25det bottom end. as far as i can tell its worth getting the rb30 if you can. the problem with searching is you hear alot of this works and this doesn't, then the next thread says the oposite. i read you cant use vvt on the , but you obvesouly have it working on yours.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
pirate87 used to have bottom ends but I think he sold all of his.
VVT works if you know how to plumb it. It isnt hard, but u have a lot of lazy people who just delete it. It is pure internet rumor and regurgitated misinformation. After being on SAU or any other web forum, you learn who to trust and who to ignore.
IMO, higher displacement will be worth it if you add cams and valve springs to help the head flow more air since it is only designed around a 2.5 or 2.6L block. Definitely get an RB26 head if you are starting from scratch and have a choice.
67 411
thanks for the good info im gonna try and collect some links about the rb30 here for anyone who is searching.http://autospeed.com/A_111342/cms/artic ... ..htmlsome of theese sites have some good info and the last one is a cool build.
Modified by 67 411 at 2:22 PM 10/3/2009
cdorhout
Next project TBD
Here is the exact thread which explains how to retain VCT without external oil feed lines. I know it works because I convereted to this after having run external lines and having them leak.This keeps all of the oil internal, and VCT still functions. It's entirely too easy to not do (if you are using a RB25DET head)
mott6904
Was it worth all the issue you faced when building the rb30? i have a rb20 s13 and im about to pick up a 97 240 and i just cant see myself swap my rb20 over to that body even though it makes good power. Im going rb26, rb30, or a ls2.
cdorhout
Next project TBD
Cool motor, sounds badass, more torque, way quicker spool, conversation piece, tons of potential, and added more value to the car than it cost me. I'd say it was well worth it.
67 411
thanks for the link that will help alot, if you dont mind me asking how much did the rb30block cost you? i am haveing a hard time finding one under 1500.
cdorhout
Next project TBD
$1,000 from Pirate87. I can't remember if that was shipped or not though.
67 411
cdorhout do you have a build thread i can read, or a photobucket account i could check out your pics on?
cdorhout
Next project TBD
Yeah, here it is.zer...a-nap
Ignore the external oil lines in the build thread, I later removed those and went with the internal oil mod.
