Darius »
https://forums.nicoclub.com/darius-u5470.html
Thu Nov 26, 2009 7:29 am
600cc injectors and a 3076R will not be enough for a forged bottom end RB30. MAYBE if the 3076 had a large exhaust housing. The Z32 MAF will probably be short lived as well. At a minimum, go 35R.
So before you drop any money on an ECU, evaluate your power goals. Things aren't as straight forward as a MAP based system once the Z32 MAF sensor is maxed out.
Are you planning on keeping the VCT on the RB25 head or just blocking it off? If you are keeping it, the intake cam gear won't be necessary.
I'm not sure about Gizzmo electronics because their 2-step is awful. I'd invest in a decent boost controller. OR if you decide to keep the RB25 MAF setup, you can just get the Apexi boost controller kit that plugs right into the EMS.
Catalytic converter?? WTF for? LOL!
