hey i just dropped my rb26dett in my s13 car and i am not getting any spark.. injectors works just not spark
Here's the list if things i checked..and there good
Checked codes 55CasCoil packsIgniter Chip EcuNew spark plugs
I checked the big white wire out of the 3 that go's to the each coil pack and i go 0 volts. I know it should be showing 12+. I am pretty sure its the wiring maybe skipped one wire when i was wiring the harness up or it might have a short..
Dose anyone know what wire out of the 6 would not give me a spark if it wasn't hook up?
Main ignition switch12v unswitched though eccs relay12v switched though eccs relayEccs relay groundFuel pump relayPower to ignition. This is the wire that i am not to sure if i hook up.. I look at the how to wire the rb26dett file and It doesn't tell you what color wire or pin out need to be hooked up.. Is the same black/red wire as the main Ignition switch??
I'd appreciate any suggestions
