the_momo »
https://forums.nicoclub.com/the-momo-u29599.html
Thu Oct 26, 2006 4:50 pm
not even remotely. the only similarities between the two are1. six cylinders2. two turbos3. strong transmissions4.strong aftermarket support
thats it. the vg is FAAAAARRRRRR more complex than the rb. (thats in my experience, i have not worked ona rb26, but rb motors are fundamentally the same. i have an rb20. i have worked on both tt and na vg's i hate them, i hate them a lot)
that being said. both are expensive. both require custom wiring and fab to work in an s chassis as the car wasnt ever offered with either motor.
if you can spend the money, do the rb26. if you want an "easier" fast car, do an sr20. easiest swap into the s chassis. or turbo the ka. you have a lot of choices, 2 of them you are curious about, but they happen to probably be the most labor intensive and expensive of all logical swaps to do.
i have a sbc in a s13 and a rb20 in an s14. neither was cheap or easy to do or work on. but it can be done if you have 1.time2.money3-1thousand. patience
good luck! and welcome to nico!
