Dyl510 »
https://forums.nicoclub.com/dyl510-u145016.html
Fri Oct 09, 2009 2:35 pm
hey guys, new here... seemed to have a bit of trouble when I originally posted this... a little confused, I don't exactly know what a "sticky" is. I don't use forums much, so in hopes this won't get deleted:
I'm looking to put an RB26DETT out of a 1992 GT-R skyline into a hot rod project of mine, but have a few questions before I decide to buy the GT-R for parts.
For starters, I would need to swap transmissions to make it 2WD, I'd imagine a 5spd out of a GTS RB20DET would do the trick? If so, would I need the RB20DET bellhousing to go with it? Or would it work with the bellhousing already on the GTR's RB26?
Also, I hear the transmission gearbox from the KA24 is the same as the RB20? I'd think finding one from a KA would be easier/cheaper than from an RB... but I'd also imagine the KA gearbox being weaker and not able to withstand the RB26's power (I plan to run appx 300-350HP).
Brings me to my next question, I know Nissan likes to keep it simple with parts interchanging, but with the 2WD transmission on the RB26, would the clutch/flywheel assembly be the same? or would that have to be swapped as well?
And last but not least, I hear so many horror stories of modded skylines and their computer issues, so I have to ask..... would the 2WD set up mess up the RB26's computer to any extent?
ANY info is greatly appreciated guys, thanks in advance.
Cheers, Dyl510
