rb26dett problem need help
farmer
Car: 1990 nissan 240sx
as some of you know i have installed an rb26dett into my 240sx (1990), ive got the motor running and everything is cool. My list of upgrades include a large fmic, 550cc injectors, walbro pump, apexi avcr, graddy bov, and an spl tuned computor.
my problem is this. the car idles fine and sounds very strong, when i put the car in gear and let it roll around 1500rpm and hit the throttle the car bogs heavily and almost feels like its goinna stall, but when the car hits boost it goes like a bastard until 6600rpm when it starts to backfire and sputter
i cant figure out whats going on here, i know this isnt normal
an example of this is
put car in gear and let idle ,hit gas and car sputters and bogs as rpm climbs, car goes into boost and pulls real hard (.8 bar ) rpm gets to 6600prm starts to sputter and bog again, switch gears and hammer on gas ,car bogs and then picks up again
im thinking that i might have an issue with the ecu i have , the place i bought it from said the ecu came out of an r32 with n1's 550cc's and fmic so i figure that this would be the same for me (but i only have the stock turbos) but this i purchased the ecu from has given me nothing but bs about everything i purchased from them
if anybody has has this issue and can shed some light on this issue it would be greatly appreciated.
also i would like to try a stock r32 ecu in my car to verify if this is the issue , if anybody in the GTA area could help me out that would be great as im in oakville
thanks
farmer
gawdzilla
Car: none
you cant expect to pick up some ecu with similar bolt-ons and expect it to work on your car. you're probably experiencing a lot of richness when you first step on it, thus the bog. Get a real tune with wb02 and egt and you'll know for sure. there's no point in guessing at it.. its a bad idea and you'll end up breaking something
DrifterTom
Car: 90 rb20 coupe
he has spoken the truth, don't cheap out or screw around with engine manangement. guessing at tune is cheaper in the short run but knowing things are right equals less money in the long run
farmer
thanks guys, i was leaning to getting a tune done, that might also explain why the car runs hot , that could be also the fact that im runnig my fans in the push configuration
thanks for the input guys ill keep you posted
p.s. heres a few pics ofthe car
http://www.cardomain.com/ride/2227290
farmer
Shocker
Car: 89 240sxHB rb26/30
good work on the bay, im gonna agree with gawd 100%, get a good tune. sorry to bash, but that kit is fugly, good color, but kit makes me nautious same with the rims.. o.O
Valley
Car: 00 celica gt-s 89 240sx hatch
so... you've checked timing, mafs, fuel pressure and all that good stuff? sounds like my problem with timing, i couldn't get my rb25 above 6k
as for the bog at shift, sounds like venting problem DSM's have. are rb26's recirculated stock? if so, recirculate it, don't vent to atmosphere as it looks like you're doing in you engine pic.
