RB26DETT Oil Line Turbo ????
drftns14
i need to know what is the type of fitting i would need(thread pitch/AN/NPT) to get to run my turbo oil feed lines and also are the two oil feed spots on the side of the block(where are the two located)PIC and/or/do i just "T" the one? thanks
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
Just use the factory ones there fine. If you make ones they are going to be suppling too much pressure to the center sections and blow out the seals right away. Have fun rebuilding turbos if you make your own lines. Call HKS they will tell you what kind of restrictors you need. AGAIN SEARCH I know its been coverd before.ENOUGH WITH ALL THE QUESTIOS YOU DONT NEED TO ASK. you could have posted this in one of the two posts you just made about the same thing. The olney thing is your spamming up this fourm with questions that dont need to be asked. No wonder why its hard for new people to find info on there swap. Im not saying my poo dont stink but please learn to respect this fourm so its usefull to others.
themadscientist
it searches, seriously.
