Apexi said to install the map sensors in the 3rd and 4th throttle body after the butterfly. it has become the general consensus though that you can use the balance tube running above the throttle bodies. This was will give you a stronger vacuum reading as the throttle body mounting often causes fluctuations on light throttle.sr20tom wrote:I know this sounds stupid, but i am having trouble with my map sensors on the power FC. They are always reading a + pressure. Now would the ITB effect the pressure in the manifld or do i need to plumb it from the little nipple behind the itbs. i guess this can be compared to a regular car where we have pressure on the charge pipe and pressure inside the manifold after the throttly body. In other words is it the same pressure before the throttle bodies as it is after the throttle bodies? Thanx
