Ok, I have an R33 Rb26dett and it seems that the Power FC is the way to go. Now I have seen a ton of these outfitted with Power FCs but most of them have the stock or z32 AFMs on them. I plan on putting down between 400-550hp at the wheels. I don't want to be a dyno queen so peak horsepower is not that important to me but rather having a nice fat power band. So my question is which Power FC setup to go with, and why? The D-Jetro illiminates the the AFMs and you install one or two maps sensors instead. Money really isn't the question here since for the additional price of the D-Jetro version I could easily buy a couple of Z32 AFMs. Pros/Cons? This car will be street driven from time to time so starting up and ideling is a good thing and the car may need to pass smog in either California or Arizona. Any info would be greatly appreciated. Also, if anyone has any good base maps or knows where to find some that would be great also. Not sure if I will have it tuned to pump gas or race gas yet. It will be street legal but not a daily driver.Thanks in advance,Tim
upgrade list:Power FCMild Cams with adj cam gearsBNR34 N1 spec(steel wheels), full BB option660cc injectors and fuel railNismo Fuel Pump 276 L/hrJun Oil PumpN1 water pumpTomei Head Gasket Kit 1mmARP Head Stud kitATI crank damperGreddy IntakeHKS style ex manifolds and down pipesOil CoolerNice aftermarket FMIC with hard pipesRising rate FPRetc......
