Vrtgrumpy »
https://forums.nicoclub.com/vrtgrumpy-u2381.html
Wed Nov 19, 2003 9:09 pm
The kit is NOW finished, we had to make some changes to the prototype to fit the S13 and S14 correctly. Plus, the lawyer is taking forever on the patent paper work for the mounts, sway bar, and the down pipe.
AND, trying to get someone to produce our downpipe with out taking my arm and leg is getting hard. Got a meeting with another place tomorrow. Pray this one works out.
Anyways, Yes you can use the Rb26 oil pan. But you have to cut off the front dif and do alot of grinding to make it fit right. It is real tight between the pan and the crossmember. Plus, you'll have to switch over to a custom sway bar. As the RB26 pan will hit the sway bar.
Best way is to run the RB25 oil pan, but everyone has their way....... Mine will have the modified RB26 pan and the other one will have the RB25 pan on.
As for the transmission's. Have anyone ever tried to pick up a RB26 one. Dam that thing is like almost twice the weight of the RB25 one. I would never try to put that into a 240, way to much trouble and weight. But thats me.......
As for the transmission mount kit be avalible for the RB26 transmission. Don't think so, it would be way to much work to get that to fit right. I really don't feel like cutting up the floor of the 240sx to fit a transmission in it. Our main idea for the mount kits are to keep this swap as simple as possible. Nothing to hard or something that takes up too much time. If you REALLY want the 26 transmission to work in your car, just send the car to us and I can do a "one Off" one for you.
I hope I covered everything.
Oh yea, my car will have the RB26DETT in it for the NIssan fest next weekend. You'll be ablt to see the new kit and the down pipe as well.
Here is apick before it goes into the car..................
Grumpy
