All r32 and most r33 rb26's suffer from the crank collar issue. That is the olney problem with rb26's as long as you do proper maintenance. Like water pump, timing belt, gasket set ect...... Think of how long the engine has probly sat. I use to have a rb20 trans on my rb26. The rb26 clutch and flywheel will work as long as its a push type clutch. Im running a os giken clutch that was originally on a rb26 on my rb20. People use rb25 trans because they are like twice as strong as long as you use the correct fluids. The rb20 trans is the same as a ka/sr trans. Ive seen too many shattered gears in drift cars from my friend's sr's. But rb20 trans are easy to fix you just swap bell housings with a ka trans. Ka trans can be found for 40-100. ALL I HAVE TO SAY IS USE THE FLASHING SEARCH BUTTON ON TOP CENTER OF YOUR SCREEN. You will learn more by just reading old posts then asking dum questions about something you know nothing about. Learn about the engine then ask questions. Just putting big turbos on the engine is going to get you no were. You have to have all the other supporting mods to make then work. The car is olney as strong as its weakest link. One could tune the car for 350 hp with stock turbos, upgraded air filters and nice exhaust. I would spend money on things to tune your engine and make it run good before one blows money on turbos. 350hp is more than enough to blow apart a rb20 trans. Spend the money making the swap work correctly not on dum parts that you don't need. Or you will be half way into your swap broke as a joke and with a crappy engine that just going to blow up and cost you more money. I hope you have 10k saved to do the swap correctly. This is not a budget ballin swap. The engine is olney as good as its tune so make sure you have money for tuning and parts once you do get the swap running. Im real sick of typing JUST SEARCH you will be best off. A post like yours comes once a week by noobs. It gets real old your lucky I even responded or anybody.S15nS13vert wrote:rb20 transmission on a rb26dett?????? do you have a r32 rb26? most of the people use the rb25 or the z32 transmission rb26 from the r32 i heard it has problems, but i don't remember what were they
no the purpose is because the stock shaft doesnt work in a RB25 transmission (what usually goes in with a RB26)skylinegrl13 wrote:i don't know if the s14 driveshaft fits an rb20, but even if it did why would you use it?? the purpose of upgrading to a one piece driveshaft with the rb26 is about strength as much as fitment - remember you are almost doubling your torque and hp. good luck.
correct me if i'm wrong, but that's only for the r32 rb26dett's never on the r33+ rb26dett's1- iirc rb20 trans should bolt on to the 26 block2- rb25 flywheel/clutch 'push' type, late r32 rb26's and up are pull type3- i believe you can use your stock driveshaft, my friend has a stock rb20 in his s13 and he's using the stock driveshaft, i don't see why it wouldn't apply for s14 as well6- i sold some left over parts to someone with an gtr33 skyline vspec, @12 psi i believe he said 306 awhp? somewhere around there to ALL FOUR wheels..most you can boost on stock turbos is 15/16 then the ceramic wheels start to fall apart, not sure how much hp difference each psi can bring but you don't have to do much to get around 400..s14 2510’s wrote: All r32 and most r33 rb26's suffer from the crank collar issue.
my r33 rb26 trans is pull styleKamin wrote:so im not crazy! i knew i had seen a push r33 26. lol
