Rb26dett Full race Single turbo conversion- Water and oil line help
streeteg
OK so here is the story---- Below is a pic of the exhaust side of an RB26block stripped in preparation for a full race single t4 turbo kit. Each piece either flows oil, coolant or vacuum, and I was curious to know which was which in regards to oil feed, return, water feed and return and vacuum. Going from 2 turbos to one threw me for a loop--- any insight?
Also, There is another coolant line that wraps to the front of the block that goes into the thermostat.
For those curious the car is a r33 skyline.
Modified by streeteg at 6:08 PM 12/15/2009
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Depends what kind of turbo you are running. All you do is use AN lines for a single oil line (and a water one if you have a water cooled turbo) and fittings to block what you don't need.
streeteg
Its a t4 gt35r---and there are a few places it looks like the lines can come from-- I just havent done it before. THe pics will say more then I am able toso I will get them up when i get back from work tonight.
streeteg
pics up
sr20tom
so far we know that oil return is #1 and oil feed is #2. The rest we are not too sure about. All the help is much appreciated
Bluefire
2 is your oil fead1 & 3 are your oil returns. Pick one and cap the other.4 is one of your water inlet/outlet. The other water inlet/outlet comes from the upper water neck in front of the motor. 5 is vac/boost. cap or use for your wastegate6 is probably another vac/boost, but it shouldn't be way down there. I'm guessing the line is bent and should actually be up by 4&5.
-Bluefire
sr20tom
just what i was looking for. Now when you say inlet/outlet does that mean its a feed or a return. Where do i get the water feed from and where is the water return? What size fittings are they and what size line should we use?Thank you for all the help.
noodl35
sorry to be offtopic but aren't those rb25det mounts? My r33 rb26dett came with those mounts and I was told those were rb25 mounts. So I sold those and got the supposedly "rb26" mounts. Look at pics below. Can you please verify?
Here are the "rb25" mounts that people were telling me it should not be there
here are the "rb26" mounts I bought to replace.
This r33 rb26 is going into my s14 with Mckinney mounts. Should I be fine?
sr20tom
they look the same. the car is a gts with an rb26 and at 25 trans
noodl35
ahhh okay that makes sense then. So streeteg must have put the rb25 mounts on that rb26 block. I guess it doesn't matter much anyway as rb25 blocks and rb26 are identical externally. I was just worried on the mckinney mounts that were made for a rb26 and not rb25.
noodl35
sr20tom wrote:they look the same. the car is a gts with an rb26 and at 25 trans
Yes I know they are the same. When I received the motor, it had those rb25 mounts on them. Maybe r33 rb26's came with rb25 style mounts ? I duno..
Bluefire
sr20tom wrote:just what i was looking for. Now when you say inlet/outlet does that mean its a feed or a return. Where do i get the water feed from and where is the water return? What size fittings are they and what size line should we use?Thank you for all the help.
yes feed and return. I don't exactly remember which is which, but it really doesn't matter anyways. Just run one water line from the water neck to one side of the turbo, and the other water line on the back of the motor to the other side of the turbo.
As far as line size, -6 is what I normally run. there is no real need to run any bigger.
-Bluefire
Bluefire
noodl35 wrote:sorry to be offtopic but aren't those rb25det mounts? My r33 rb26dett came with those mounts and I was told those were rb25 mounts. So I sold those and got the supposedly "rb26" mounts. Look at pics below. Can you please verify?
The only real difference between Rb25 and Rb26 mounts are that Rb26 mounts are designed to allow clearance for the front turbo.
sr20tom
Bluefire wrote:2 is your oil fead1 & 3 are your oil returns. Pick one and cap the other.4 is one of your water inlet/outlet. The other water inlet/outlet comes from the upper water neck in front of the motor. 5 is vac/boost. cap or use for your wastegate6 is probably another vac/boost, but it shouldn't be way down there. I'm guessing the line is bent and should actually be up by 4&5.
-Bluefire
Here is another question. Lets say i wanted to block the second (rear) oil return, does anyone know what size that 2 bolt flange is or should i just bold it back up and just cap it somehow for now?
gawdzilla
Car: none
sr20tom wrote:Here is another question. Lets say i wanted to block the second (rear) oil return, does anyone know what size that 2 bolt flange is or should i just bold it back up and just cap it somehow for now?
it's super easy to make one. just take off the original 2 bolt piece and use a marker to trace the outline on a small piece of metal. cut it out, drill 2 holes in it and you have your blockoff plate. find some shorter bolts and bolt it on. use a bit of rtv around the outside so it seals against the block.
gawdzilla
Car: none
this should help you out for coolant. i don't remember what 4 and 5 are, but i don't believe either of them are vacuum. either way, you should be able to trace it and figure it outhttp://forums.nicoclub.com/showthread.php?t=169158wtf this forum won't let me link to freshalloy and keeps changing my url. change the "nicoclub" to "freshalloy"
the original diagram is missing one of the coolant sources from the block. it's under the cylinder 6 freeze plug and can be seen in the 2nd motor pic posted in this thread
Modified by gawdzilla at 2:11 PM 12/17/2009
sr20tom
gawdzilla wrote:this should help you out for coolant. i don't remember what 4 and 5 are, but i don't believe either of them are vacuum. either way, you should be able to trace it and figure it outhttp://forums.nicoclub.com/showthread.php?t=169158wtf this forum won't let me link to freshalloy and keeps changing my url. change the "nicoclub" to "freshalloy"
ok on your link now how did you do the water plumbing? Did you utilize the freeze plug water source or did you use the the #4 in my diagram to the turbo and then the turbo to the thermostat neck?
gawdzilla
Car: none
You'll see later in the thread someone recommends a way to do it, so i did it that way. i looped the #4 line back on itself near the source somewhere on the intake side so its not being used.
then i used the thermostat neck and the freeze plug water source as my 2 connections to the CHRA
sr20tom
gawdzilla wrote:You'll see later in the thread someone recommends a way to do it, so i did it that way. i looped the #4 line back on itself near the source somewhere on the intake side so its not being used.
How exactly do you loop that #4 line onto itself? I plan on taking the intake manifold off and removing the metal lines running behind the motor, but how do you loop that line? Do you take plug the hole that its coming from or just run that line ito somewhere else?
