RB26DETT exhaust valve guides and valve seats
gawdzilla
Car: none
anyone know where to get?
accel junky
Try mckinney or search the aussie boards for an aussie company. I've gotten some stuff from the aussie's but shipping takes a long time and some are dishonest.
technorb26
gawdzilla wrote:anyone know where to get?
Are you rebuilding the head?
On a side note: is your RB26 out of a R32 or R33?
gawdzilla
Car: none
33.. yes rebuilding the head. i found the valve seats. p/n is 1320558s00 for those who care. p/n for exhaust valve guides is 1321305u10.
the seats are usdm parts on the vg30 it looks like $.41 a piece. cant find the exh valve guides though
Phat_Optimo
Car: 93 S13 SE
Tomei has brass valve guides. Jun also makes them. http://www.aebsracing.com/main.plThis place is the Tomei US parts distributor.Sorry to hear about that bro.
technorb26
gawdzilla wrote:33.. yes rebuilding the head. i found the valve seats. p/n is 1320558s00 for those who care. p/n for exhaust valve guides is 1321305u10.
I need your help! Since you have a 33, can you look at your igntion subharness, and tell me if the main plug that goes to the EFI harness ( all the way in the back of the valve covers), is a big gray plug with 3 wires. This is the plug for the ground and +12V that go to each coil. Not the plug for the power transistor unit though...
gawdzilla
Car: none
yea, it is a moderately sized grey plug with 3 wires. the gauge on the wires is a little thicker than others. i don't think there is a difference between 33 and 32 for this, is there?
a correction to my p/ns... 1320558s00 are actually valve spring seats. (int and exh are the same x24). this is the one that is usdm, $0.41.
exhaust valve seats are 11099-05u10 not usdmintake valve seats are 11098-05u10, not usdm
technorb26
gawdzilla wrote:yea, it is a moderately sized grey plug with 3 wires. the gauge on the wires is a little thicker than others. i don't think there is a difference between 33 and 32 for this, is there?
Thanks! I just wanted to confirm that. Because my harness misteriously ended up with a small black plug with 2 thin wires there. A lot of headaches...
PurpleGodzilla
what about intake valve guides? do you happen to have those p/n ?
gawdzilla
Car: none
yea, i can look it up when i get home tonight
gawdzilla
Car: none
purplegodzilla, the intake valve guides are 13212-05U10. let me know if you need anything else for the 26.
