TheOne »
https://forums.nicoclub.com/theone-u18820.html
Sat Sep 10, 2005 2:30 pm
sure you can, you just need a LOT of money for a LOT of custom stuff, like longer front end, fabricate the back so you can put a rearend since the car is FWD(unless you take out the driveshaft and just use the front transfer case, not sure if that can be done), and you need to do a lot of other custom things that'll make the car not streetable.
i mean, well you can do anyfin with $$ right?
