themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Thu Dec 06, 2007 2:18 pm
Just remember it is not boost that unseats head gaskets, it's detonation. I ran 8 years on a bigger turbo with the original HG. As soon as I pushed the fuel system past it's capability and leaned out POP!Metal head gaskets resist the destructive pressure spikes a bit better than OE but if your engine is knocking they pop just as easily. I would not recommend going with a thick gasket. The taller the gasket, the more it is exposed to the events in the combustion chamber. Also the gasket is not as rigid as the block and head castings which could allow things to shift. I would go with the thinnest gasket possible and get a compression drop from dished pistons or chamber work.RB26 head bolts are beef, you would be hard-pressed to lift the head if properly installed. Studs give you the advantage of locating the gasket during assembly and making the torquing more accurate. A bolt has two forces acting on it when torqued, stretch and torsion, the twisting force. A stud sees really just stretch and is thusly more accurate and stronger. It is by no means a requirement though, properly installed bolts get it done.
