RB26DETT 93 240sx Convertible Project
ghost_22_47
Car: 1993 Nissan 240sx Covertible with RB26dett
2004 Audi A4 1.8T Quattro
!!!VIDEO!!!
Replaced my hoses with the leftovers from running the blowby.
Tried testing something and blocked off the hose going to the intake and opened the valve cover to the atmospher to see how it would run and my A/F jumped to 17-18 at idle. I ordered a filter and I am going to put it on that valve cover instead of the hose and block the intake section again and see again how it runs.
When I inspected the old hose it has a big metal block shoved into the hose to block air from the intake into the valve cover. So if the filter idea doesn't work then I will block the section of the valve cover off.
It's confusing because I have see all these different ways done, in mags and internet pics so now I will play with it and try and get it as smooth running as possible, since I took that hose with the block in it out the motor went back to rough idle and bogging.
ghost_22_47
Here you go guys, I torn my engine apart (well a good amount of it) Sunday to torque down the head bolts and check some stuff.
The headbolts did move some
Tear down took 1 hr to 1.5 hrs wasn't keeping track just know my wife showed up from work just in time for the aftermath and devistation of my only vehicle in peices in her dads garage ha ha ha.
The pics are in order of my disassembly
Found my other O2 ha ha ha
No BS ashes in my turbo IC collector pipe (Me thinks they never touched it)
Plugs looked ok but not pretty
Yup I did it CAS was removed :|
Well after all of that I threw it all back together
Started it
AND
Smoke and s**ty idle
Played with the CAS and IAAC while the wife screamed out RPM's and A/F numbers and the outcome?
Perfect (so far)
Idle is alittle high at start up (1000)
but the A/F is dead on 14's at idle and cruise and under boost is at 11-12 no smoke no bogging and it doesn't burn crap loads of fuel anymore. It only took 20 mins of anger and plumes of smoke out the back and very unsteady idleing.
The shop never adjusted any of it (or not enough) because now it runs great :rolleyes:
disturbed.)
Car: 94 240sx vert sr20det 5 speed gt2871r dead for now,
04 Frontier XE vg33e 5 speed HG46
where did you get the ports for the bumper i cut bent and welded ports in the steel but am afraid of hacking into the plastic without something to cover up how lousy i am with a diegrinder are they off another car or did you order them from some1?
ghost_22_47
They are carbon fiber N1 vents for a R32 N1 GTR, sorry to say I ordered them from australia but you can pick up non carbon fiber around pretty easily but the fitment isn't that great. The vents have more of a bend to them so they pop out more than I wanted but they look good from a distance. I would look at the R33 N1 vents, look at the bumper in pics it may have less of a bend and I think I saw a set on ebay for 40$, or check gtrcanada.com they are always getting rid of stuff.
reborndub
Car: 1990 vw corrado g60
2009 honda civic si
1997 chevy silverado z71
:wavey: im gonna bump this!! :wtf2: the latest on this pig?
oh and why havent i set my a** in this yet? (jerk) :nono:
dont be a stranger,give me a call sometime!! or e-mail :slap:
S15nS13vert
Car: 95 240sx with a s15 engine 6speed transmission, 94 S13.4 SKYLINE VERT and a 08 Lexus RX350
nice RB , have fun, i wish i had an RB under my hood.
i heard u wanted to go kouki front, i like the oem bumper( they dont crack )
i went Kouki front end on my car, i love the way it looks, some people don't agree, but to each its own
the fiberglass bumper doesnt last long, so i bought OEM bumper
truckmtr240
Car: 91 240sx hatch
looks so much cleaner with the oem bumper
240vertsr20
Car: 1992 240sx convertible sr20de
dayyymmmmm bro looks really good id like to drop one in my 92' vert....someday....very jealous not gonna lie. S15nS13vert dude i swear i have seen your blue vert in a neighborhood over by the turnpike in i think its pompano....i was doin fire alarms in there at the time...just wondering if u live there we should get together sometime just got my 92 vert and could DEF use some advice and help with it
S15nS13vert
i will be glad to help e-mail me [email protected]
Martin
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
Lookin' good.
That boost creep is because your exhaust is too free-flowing. Add another muffler in the middle and it should hold boost. :)
You've already spent so much money on this beast... why no standalone ECU and tune?
ghost_22_47
The boost creep was a stuck wastegate.
s13beast
Car: 94 5spd silvert S14 SR
91 hatchback dd
Goodjob man. That bumper is terrible though. What coilovers are you going with?
ghost_22_47
I have tein super drifts on it.
S14 front end will eventually go on it so until then I'll rock gross bumper
mattblancarte
ghost_22_47 wrote:The boost creep was a stuck wastegate.
Haha yeah that would do it. :blush: I was running straight pipes to a fart can on my exhaust system and ran into boost creep from exhaust being too free-flowing. I herp derped and figured you may have been running into the same issue because you have a badass system.
Glad to hear you got it fixed! :mike
I have to admit, your carbon coil cover with the badge strip looks cleaner and just better than my cover. :bowrofl:
In regards to your A/F graph:
- Is that a single pull at full throttle? If so, what gear?
- If yes, you are leaning out/running a tad richer than I would prefer.
For premium pump gas, I'd want to see somewhere in the ballpark of a 10.7-11 A/F ratio while full throttle and at more than 6-7 psi on those turbos (3000rpm+). Stoic, non-boost situations should be in the 14.5-14.8 range.
If you choose to run higher octane unleaded (around 100), you can run in the 12-12.5 A/F.
From what it looks like, you're spiking up to 20+ A/F around 3100 RPM. That's not good if you are full-throttle. If you're not full throttle or off throttle, that would explain the spikes.
In general, you'd like to see a cleaner mix. For example:
ghost_22_47
Long overdue updates
Some pics I took before winter
Fuji SPL Meet before winter hit
New Clutchmaster clutch because SPEC sucks and burnt out in less than 5000 miles
Winter Blues while it waited for repairs
It's back up and running and I replaced the broken drivers door handle
So my wife ruined her basiclly new computer with viruses and maxing the harddrive space out with music and crap as well as whatever else she did to it, until it was usless.
She said if I can fix it I can have it and I love challenges and needed a new computer just for Nistune and school work.
It took me close to 16 hours to copy things and clean the whole system up but I did it and loaded Nistune and Logworks for the Wideband on.
:D YAY I now have a computer dedicated to tuneing, I just have to plug it in tomorrow and test it and make sure everything reads fine.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
sweet. Let us now how that goes.
mattblancarte
Very nice! Sucks that your clutch went to crap so soon. Did you break it in properly?
Waiting for more updates. :)
ghost_22_47
mattblancarte
Official note: No speed limits were broken. hehehe :D
Sounds nice and burly!
reborndub
2009 honda civic si
sweet!!!!!!!! sounds awesome!!!!!
almost warm enough for a nice weekend visit to see your damn uncle and your trouble makeing little cousins.hint,hint.
i'll let you know when driveway dries out and the frost heaves are down alittle more.
ghost_22_47
New Present from the Ebay Fairy
All in all I'm happy with it and know I will need to modify as needed but it's not bad.
Godspeed RB26DETT Air Intake Kit
I will not be using the cheapy shoom filters if anyone wants 1 or both $5 each
!!!The Problem with buying cheap!!!
Visual Porosity
Overcast sanded improperly
Sanding crazy on a sealing area
Poorly aligned holes
Welding Stalagtites
Here is what it will look like installed
ghost_22_47
ghost_22_47
BrownDogg
Car: 93' S13 coupe
Awesome build! What kind of horse power and torque numbers did it make on the dyno?
ghost_22_47
It made 330HP and 280FTLB Torque @6700 with still a coil pack break up, Getting new Coil packs and rev limiter is set to 7500rpm so once I get those in and do a quick air/fuel and fuel and timing map check it'll be going back on the dyno.
max-8508
Car: FRONTIER
you are :dblthumb:
i have frontier 2004 , can i swap my engine from (ka24de) to (rb26dett) ?? or onther RB??
biggie
max-8508 wrote:you are :dblthumb:
Anything is possible with enough money. But also have to consider legal issues of inspections.
max-8508
Car: FRONTIER
how mony do i have to swap?? :sad:
and do i have to cut in my car??
ghost_22_47
max-8508 wrote:how mony do i have to swap?? :sad:
I'm not entirely sure what your asking but you would have to heavily fabricate and modify parts to make it work in a Frontier. Anything is possible though, but here are some deffinites. Wiring harness would have to be chopped up and modified, drive shaft would have to be specially made, exhaust sytem would have to be specially made, crossmember would have to have some reasearch done whether one would work or one would need to be made, if you want all wheel drive then you'd need a specially made front driveshaft, custom axles yada yada. In other words if you have the knowledge, money and don't expect to drive the car for over a year then go for it.
ghost_22_47
Picked this up yesturday
1990's Nissan NX Digital Cluster
I will be converting the wiring and installing this soon.
It had 152,000 miles on it and my car has 192,000 so I opened it up to correct the milage.
Removed the Odometer and corrected the miles to match the car I would explain but for legal reasons I will refrain from telling people how to do this kind of thing.
It says 198,000 in the picture but I corrected it again
