RB26dett 510 build
RBDatsun510
Hello all, I've been looking at a few engine swaps to put into my Datsun 510, and I believe I have decided to go with an RB26dett.
Are there known complications in doing this swap?Any information about these engines and the swap is greatly appreciated.
The car will be used as a track car hoping to make about 650 whp. Does this seem a reasonable option?
thanks in advance for the info.
Jason
Joe
LOL 650hp in a 510 for a track car?
youre f***ing crazy. youll NEVER put that power down.
i have a bigger car, with more tire capabilities, and can barely control 400whp on a R comp tire.
raremotive
Car: 04 Infiniti G35
whats wrong with a rb25?
you should base your HP on your tires.. that's all I am going to say...
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
keep it cheap and just get an rb20 or hell even an sr20. You can get 300rwhp out of an sr20 alot cheaper than it will cost you to modify an rb. If money is no object and your a baller for a 4k plus rb26dett i say do it.
FAST-DATSUN
will require moving the fire wall back and custom frame built to handle the power, custom mounts, radiator, intercooler, very short drive shaft, cutting out the trans tunnel and making a new one...plus alot more. Go with a CA/KA or SR....
Joe
FAST-DATSUN wrote:will require moving the fire wall back and custom frame built to handle the power, custom mounts, radiator, intercooler, very short drive shaft, cutting out the trans tunnel and making a new one...plus alot more. Go with a CA/KA or SR....
and that is from someone who has been building RB cars and 510's since the beginning of time.
listen to him.
PorkChopExpress
Car: rb kouki
i have always wanted to put a 3 rotor in something like a 510,,, someday.
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
PorkChopExpress wrote:i have always wanted to put a 3 rotor in something like a 510,,, someday.
My buddy is almost done with his 13b turbo 510. After it's tuned, it should be making around 400-500whp depending on the boost. It's his first track car...
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
stick with a rb25 for cost reasons, (already get the 25 transmission w motor) and do a few bpu and some sorta ems, youll be happy at 350-400whp on that body!!!!!!
400-700 whp is scary as hell in a s body let alone a 510
FAST-DATSUN
510 rb25det for sale in Bakersfield ca.....ready to drive rad and intercooler in the trunk...
SullivanRacing06
damm, sounds nice, exp comming from mack
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Why not a VQ35?
stevespeed
Car: RB-Swapped S13, FTW
intercooler in the trunk?
