RB26DET - Single Turbo Swap Plumbing Greddy T78.
Greddy T78, non-water cooled, non-BB. External wastegate...will these work?
#1 oil return from turbo - 3/4BSP or 3/4NPT? Is 12AN too big for an oil drain?#2 oil supply to turbo - M12x1.0 to 4AN? Do I need a restrictor for non-BB?#3 oil return from turbo - Blocked.#4 water from turbo. - Not needed for non-water cooled turbo?#5 boost pressure - To external wastegate?#6 sense line from turbo inlet to boost pressure control solenoid - To boost controller?#7 water to turbo - Blocked on non-water cooled turbo?
Thanks in advance!
