Kansei240sx wrote:
You understand very wrong. In any new nissan or any other company for that matter post OBD-II or even OBD-II vehicles, have multiple controll modules, such as TCM, ECM, bla bla bla.
It does not work that way exactly with the 350Z. If you remove the stock ecu, you lose pretty much everything. Headlights, windows, gauge power/lighting, CAN bus, turn signals, etc etc. And yes, I am positive.
So for this swap, I will have the stock ecu running all the body electronics and whatnot and then have the RB26 ecu (apex'i pfc d-jetro) running the engine only. Wiring is going to be a pretty big pain in the ***, but is doable. As far as gauges go, I am going to try to use all of the stock ones. But will probably end up just using the 350Z harness and sensors along with the RB26 sensors, so I don't have to worry about the Z gauges taking a different signal.
