How sure are you about that idle speed? I thought it was closer to 650rpms. I'm confused, i'll check my FSM tomorrow at the shop.gawdzilla wrote:the 26 is supposed to idle higher.. but not that high. around 11-1200 i think is what the fsm says. block off your holes and try to fill the tract with compressed air to check for leaks. if not, adjust your aac. you should be able to reach under the manifold with a small flat head screwdriver to adjust the idle
lol, just buy a new rb26 thats a easy fix its only 4 grand **** it haha Nice GTR btw!Carl H wrote:or his throttle gaskets are leaking, but he wont check them like he should and start throwing parts at it to fix the problem.
contact cleaner, carb/brakleen is like acidDavid_NISMO wrote:What about the "fuel injection intake" cleaner stuff? What do you suggest.
By the way, take the carb cleaner and spray it all over the TB gaskets and listen for a drop in rpms. If you get it, you've got a leak
That's what i used... not carby cleaner ... i just said that for the quickness... i used some stuff that's good for fuel injection intake blah blah blahDavid_NISMO wrote:What about the "fuel injection intake" cleaner stuff? What do you suggest.
