sr20tom »
https://forums.nicoclub.com/sr20tom-u141833.html
Fri Mar 05, 2010 8:20 am
it is a puch type clutch. The bolts all seemed to lign up on the flywheel and the disks all went it with no problem as well. i did replace the throw out bearing with the one that was included in the kit, but did not replace the pilot bearing sice i figured there is no change in the input shaft and that copper ring is such a pain to pull out. There was no damage to it so i just left it. I hope bleeding the slave is all i have to do but since I never disconected it, I have a feeling the problem lies elsewhere.I know that i have to build a stop plate for the pedal in order not to damage the clutch but even with the pedal pressed all the way down, the input shaft was whining AKA it did not stop spining.
