rb26 wiring ??
Phat_Optimo
Car: 93 S13 SE
Hi, I have most of it done. Got 2 questions though. On the dropping resistor box it has 7 wires. I got 6 of the hooked up already but the odd wire white black. Is that a ground or is that a power wire splitting off the fuse box? On the boost control solenoid theres 2 wires one goes to the ecu the other is a black red. Is the blk red a ground? The engine will be going in next week.
Phat_Optimo
Car: 93 S13 SE
up ttt
gawdzilla
Car: none
looking at the wiring diagram, the odd wire out is a 12v. it shares the same 12v signal that goes to pin 58 of the ecu, and pins 5 and 1 of the ECCS relay.
for the boost control solenoid, it looks like the other wire is ignition 12v.
OlyDriftSquad
anychance i can get a copy of that
gawdzilla
Car: none
wiring diagram is in the FSM. if you want a copy of the FSM, let me know.
