Carl H wrote:rb30 block, same bolt size as the rb25/20...if i swap to a 26 head i'll tap the block out.
Wasted effort IMO, many very high HP 30's using rb25 arp 11mm studs with no issues. Including Robs 1500 hp+ FED... I was thinking of doing the same thing until I researched how many people kept the 11mm with the 26 head and are making big #'s.
As for a gasket I've had good luck with the Cosworth unit. XS Engineering (not power..) did a little review on it and compared the "squish area" of the gasket to other brands and OEM. It sealed very nicely and is also reasonably priced.
