240zdan »
https://forums.nicoclub.com/240zdan-u136082.html
Fri Jul 31, 2009 7:43 pm
i am experiencing vibrations in both my clutch pedal and shifter at higher rpm above 4-5000. the problem is apparent when in gear and moving. it does it in any gear, so i dont think its a driveshaft vibe. the harmonic damper seems to be in good shape but does wobble slighlty at idle. (no more than my friends brand new STI, though). The motor was involved in a front end collision which destroyed the water pump and destroyed the original harmonic balancer. I thought about the crank being bent, but the way I beat on the motor, im pretty sure it would have blown by now. there are no metal shavings in the oil or irregular noises coming from the bottom end.The throwout bearing is a bit noisey but i can feel the vibration in the shiftknob with the clutch released so i dont think its causing it. obviously if the vibration is strong enough to be able to feel it in the clutch pedal and shifter, i know there has got to be something wrong.
anyone have any ideas? whats causing vibration at higher rpms in any gear?my next assumption woudl be to pull the trans and check the flywheel face runout? maybe the motor had fallen on the flywheel during transportation, throwing it off whack?i guess i do have a few things to check but my real question is, what else is a symptom of a bent crankshaft? would there be any oil leakage from the front seal? i have absolutley none.
Modified by 240zdan at 10:48 PM 7/31/2009
