RB26 valve covers on a RB25 with stock cross over pipe?
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
I was wondering if you can install the RB26 valve covers and timing belt cover ona RB25 and still retain the RB25 stock cross over pipe?Also is there any way of getting around haveing to cut a hole in the front cover for the bump on the stock belt cover?Could it be spaced out?Also which holes exactly on the 26 cover need to be drilled or modified to make it fit the 25.
Thanks in advance guys.
Stealth-Z
Car: 1991 300ZX
No on the crossover pipe and the RB26 valve covers.
leesredgt
Thanks for the quick response.
moso240
Car: Ferrari V12 Powered S13
wat about 26 covers on a 20??
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
if you notice, the picture supplied above is a RB20 with 26 covers.
What is being demostrated is that the RB26 valve covers can not be used with factory style cross over manifolds.
leesredgt
I know this is kinda off topic but can you use the stock fuel rail and stock injectors with the Greddy intake manifold?
Cjmartz2k
Car: Hunting for a '89 GTR now
Yes
FinkenS14
Car: 1995 Nissan 240sx S14
So say you have a Greddy Intake, can RB26 valve covers and front timing cover fit on a 25 then?
Coolwhip
Vendor
FinkenS14 wrote:So say you have a Greddy Intake, can RB26 valve covers and front timing cover fit on a 25 then?
yes
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
Coolwhip wrote:
yes
Yes for RB20 and RB25, if you have forward facing IM, but remember for Rb25 you have to cut hole in timing belt cover for VVT/VCT .Like in this pric from zilvia.net
raremotive
Car: 04 Infiniti G35
I have a rb26 plenum up for grabs.
xX RB Xx
Car: SE3P, FC3S, FC3C.
Rare_f8 wrote:I have a rb26 plenum up for grabs.
yeah but it wont fit a 20 or a 25 right? diffrent bolt patterns for the intakes right?
meet07
Car: 89 180sx rb25det
in the picture up top that looks to be a 26 cover on a 25 engine..... Why doesnt anyone else do this??? Looks great minus the fact that you would be in the catagory of "posers"
placham
meet07 wrote:in the picture up top that looks to be a 26 cover on a 25 engine..... Why doesnt anyone else do this??? Looks great minus the fact that you would be in the catagory of "posers"
That was the purpose of the pic, if you want to put front timing cover, you'll have to cut hole in it, RB20 would look clean with RB26 covers and Forward IM. But I would rather get RB26 instead.
Because every time you pop your bonnet ricers would be"yo tha'z a skyline motor" And then would give bad name for "skyline motor", if it was stock, and u would got beat by some riced out civic with "nozzzz" .
Unless I came across a dirt cheap cover set, that I wouldn't be able to pass up
xX RB Xx
what the hell are you talking about.. of course that is a 20 with 26 covers on it, theb the other is a 25 with 26 covers on it.
i was refering to the 26 plenum. the 26 is a diffent head then 25 and 20 and i was told it has a diffrent bolt pattern than the other 2 engines. that is what im talking about.
raremotive
correct, a adapter plate is required. A plus to this is ITBs.
I don't think he was talking to you...
meet07
^^ I wasn't sorry....
Cjmartz2k
I've got 26 covers on my 25 with the 26 ITB's and surge tank. I'm not a poser though because (a) my timing cover actually says "RB25" on it and (b) I smoke most of the RB26's I come across
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Since there are no valve cover baffles made for the RB25, I have actually considered swapping out the RB25s for the RB26 valve covers so I could run the Tomei valve cover baffles and improve the PCV system. I know it is totally ricey, but can you make the arguement for form before function???
xX RB Xx
where i could i get this adapter plate?
meet07 wrote:^^ I wasn't sorry....
your forgiven
raremotive
your forgiven
zerothread/307325
Any compliant machine shop can make you one.
moso240
instead of starting a new thread im gonna bump this...
The rb26 covers on a rb20 will fit but is the timing cover backing plate needed? and why?
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
i think is rb26 on 93+ rb25 because they both have VVT on the intake side so they should both have a bump so the cross over will still work
now on rb20 there is no vvt so it dosnt need the bump so the intake sits lower so it will not fit
Cjmartz2k
moso240 wrote:instead of starting a new thread im gonna bump this...
Not sure why exactly, but I think it just has some little ears that need trimming. I still have my 25 backing plate on mine after I trimmed off the little "ears" at the top corners. Just hold it up and compare. You'll see what I mean. I'm assuming the 20 is the same way.
chaosli wrote:i think is rb26 on 93+ rb25 because they both have VVT on the intake side so they should both have a bump so the cross over will still work
I'm not exactly sure what you just said from the lack of grammer, but RB26's never came with VCT (VVT is toyota) in any year, R32-R34. The only turbo motors that came from the factory with VCT are 25's.
My89r32
Car: 89 R32 Type M
I have 26 covers that I want to put on. Only question I have is what to do with the pcv? I am running a Greddy catch can.
