I seem pull very little vacuum while on the highway (-.2x100 KPA). Do RB26s create little vacuum?
When idle or taking off of the throttle it stays at a solid -.7*100 KPA
To maintain a constant speed on the highway I stay at -.2*100 KPA, but whenever I want to speed up, it needs to boost which is kind of annoying and a gas guzzler.
RB26 Engine with GT3582r turbo.
G/M 3.5 BAR MAP Sensor
Vacuum Block located with a T-off from brake booster after check valve. Block goes to MAP sensor, WG, WG Control Box, Boost Controller + gauge (last 2 are tee'd in the dash)
The nipple off the intake plenum (Front most cylinder) is routed to my BOV, and the vacuum tube at the front is routed to my FPR. The one at the rear of the vacuum tube engine is blocked off (OEM boost gauge source)
The two pipes going down off the vacuum tube go to the IACV and the other goes to a piece that I forget the name of
Everything else is capped off.
Is this all proper? Or could something in my tune be the culprit? Still running a very mild break in tune on 7PSI.
Thanks for any input
