rb26 transmission
AJ016
Car: 1993 Nissan 240SX
I'm planning on swapping an rb26 into my s13 and would like to know if a toyota/getrag v161 or v160 transmission could work with the rb to keep my car RWD.
maryjane
hope you have 10+k first off just for a stock swap!
you can cut the piece of the transfer case off that connects to the front driveshaft and weld a plate over it so you wount have to drop 900-1300 on a rb25det transmission (which is how every one dose the 26 swap)
searching is your friend!
please post what you said above in the rb forums, id liek to see you get flamed!
rb28z2
Car: '90 240sx hb
Track or DD? either way i would go with th rb25 transmission. If not then go with the OS Giken OS-88 6 speed. Its a race engine but can be used for DD too.
maryjane
im using a os gisken 1-3 equipd r33 rb25 transmission on my 26 thats making 500-750 whp you have no need to look into a yota transmission
AJ016
thanks for the help guys, haven't been to the site in a while.i already have the engine and got a good deal on a used v160.engine hoped to make anywhere from 800 to 1300hp (using full race turbo kit with a garrett gt45 turbo) any further help would be apreciated
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
are you going to be using this for straight line or auto cross?
you should be more worried about breaking shift forks then stripping off gears, i threw 600whp+ on m/ts for over a year. the only thing i would break would be the 3-4 shift fork.
hope this helps
AJ016
Again thanks for the help. I'll be using the car as a daily driver and it WILL see some major 1320 runs and eventually some drifting & time attack.
stevespeed
Car: RB-Swapped S13, FTW
if your RB26 swapping why not use the AWD trans that comes with it? and then just use the front diff from the RB26? Then use an R32...
Why not just buy an R32? Seriously your going to dump 10-15k in just modifications to start to make an S chassis sweet with that engine, but serious Motorex imported R32 GTR = 32k right now on ebay,
Buy that, drive the piss out of it, fix it up a little bit, then re sell it for exactly what you paid for it, instead of loosing 40k on a 240sx
not to mention
then you have a realskyline
