rb26 top mount turbo coolant lines?
drftnrps13
ok ive been worknn on this rb26 for sometime now, i got my new dal ball bearing top mount turbo, the only qestion i have is where to source the coolant lines for it. oil ive got covered. wanted to know what the fitting is from the stock coolant feed location on the block is? thanks
mello88
Car: s13
m14x1.5 fitting on RB20, probably the same for your 26...
BHFR-GTR
Car: 1993 s13
i to have been having this same problem, that is correct the bolt is the same 14. 1.5 i used a 14x 1.5 to a -6 an and ran -6 lines for my water, also instead of using the the stock return setup ( either in the water neck on the block or arround the back of the engine) i just simply tapped a fitting on the rad and ran it back into there, just wondering what size turbo are you using, im using a gt40-94, the water inlets are a 18x1.5 so i had to get afitting that was 18x1.5 to -6 that was fun
