rb26 t28 intake funnel
StricNyne
well since i am running an aftermarket ecu, i dont need my maf sensors since i am map and i wanted to figure out how i should do the compressor inlet, should i leave it as it is, or should i find funnels the ones that look like velocity stacks, and if i do that has anyone seen those before ? http://www.velocity-of-sound.com/ has something but idk if its worth it because eventually i will upgrade and idk how long the stock twins will last....and yadda
StricNyne
bump was also thinking of s screen so i dont suck poor innocent animals into my turbos
Bwana
Car: Denali
I personally prefer to have a filter in front of my $$$$ turbo, but that's just me... lol
bumblebtuna
Car: rb25/26 2fotay
you talkin about a "bellmouth" like this?http://www.velocity-of-sound.c...s.htm
there's 2 for sale in the classifieds.
zer...26217
240z4u
Car: '95 Nissan 240SX
No filters on a streetcar is a terrible idea. I don't care who tells me otherwise.
Evan
gawdzilla
Car: none
bumblebtuna wrote:you talkin about a "bellmouth" like this?http://www.velocity-of-sound.c...s.htm
zer...26217
i'd like to see those fit on the stock twins
no point in getting a velocity stack. the rear turbo needs the 90 degree fitting so its not blocked by the front turbo. if you put a stack on it it'll probably touch the front dump
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
when i converted to map sensors on my rb26dett i just used the stock rubber intakes and used 2 3/4" pipe about 5"-8" long and then bought two k&n cone filters that had the proper 2 3/4" inlet.
bumblebtuna
Car: rb25/26 2fotay
gawdzilla wrote:i'd like to see those fit on the stock twins
lol...pwned
nub
Fearsome_tea
I would use the pretty looking thing when showing the car off but normal use, I would use filters.
