drftnrps13 »
https://forums.nicoclub.com/drftnrps13-u75501.html
Sun Apr 13, 2008 1:05 pm
ok just tried to start my rb26 in my s14 for the first time. it wont start. i get spark but no fuel. futher research shows the following- fuel pump works, i get 50psi at the regulator, and i have injector firing signal and injector 12volt, and the injector clicks when told to fire! so this is what i did, i took out the spark plugs, i cranked the engine and looked/smelled for fuel vapor, nothing. now with a voltmeter/test light i checked the injector signals. each injector has its 12volt power. while cranking the engine the injectrs get ground out according to firing order. but no fuel spray! so what i did was turn the key on and let fuel pressure build to the set 50psi. i then supplied my own 12 volt to the injector and then groung the injector. the injector makess its distenct click as it opens but no fuel sprayed out??? so im leaning towards the injectors are clogged. sound right to you? let me know what u think and how to resolve this problem. thankspaul
