Hello Everyone I am having a hard time with my car, it idles great but the thing is it idles high at 1400rpms after its warm.
Not sure how to lower the idle to 900rpms
If you try to go over 4k while driving it wants to like die or it will die.
When your going to about 3k-3.5k and go to change gears the car bugs down and rpms go down and like it wants to die.
Not sure if it might be a leak but I have checked that and try to change the idle with IAC Valve with no luck its all the way down on the idle
Checked vacuum and boost leaks but really couldn't find anything and think I covered most hoses. Intercooler hoses seem to be tight and no leaks but not sure how to check for leaks on intercooler pipe not sure if that would cause the car to have a high idle ?? its a stock rb26 with stock rb26 ecu and hardness
