rb26 stock oil pressure?
shiftdowns13
Car: 2x 240sx's
i just got an rb26 running in a friends car and the oil pressure is reading 2bar all the time .. at idle and all rpms. I'm not sure what the factory oil pressure is, but that seems a bit low for a nissan motor. ... anyone have any ideas?
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
well my rb26 idles with 20-30psi and while cruising at highway speeds its at 50-65psi so what ever 2bar is i believe 25psi im not sure but its normal if its around there.
hashiriya13
Car: Cars, Racing, Cars, Racing
at 900rpm I had around 2-2.5 bar (depending on last oil change) I would get up to 4-7 or 8 bar. Only 2 bar (29psi) through all RPM's does not sound good. Something is not right.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Per the R33 FSM, the RB26DETT should have the following pressures at the following revs:
Idle____1.5 bar____21.8 psi2000___3.0 bar____43.5 Psi6000___4.6 bar____66.7 psi
