Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Tue Apr 24, 2012 2:42 pm
Unfortunately, we need more information from you when this is happening. Do you have a fuel pressure gauge installed to let us know if the fuel pump is loosing out? Do you know if it is getting spark or fuel when this is happening? This could be a multitude of things and for us to give you an idea, you will be just throwing parts at it. It COULD be an ecu, ecu relay, fuel pump, fuel pump relay, CAS, ignitor, bad ecu ground, etc etc etc etc.........
If I were you when this is happening, try swapping out to the stock ecu and see if it immediately fires up, could be a power fc issue, you never know.
