Thats him. I want to find him and get his aem ems form him becase that system is bomb and they are 1750 the cheapest i can find. He said he didnt want to part it the last post I saw he made.kouki-gymkhana wrote:His name was ctnewman and yes, he had an RB26 RHD s13 but ended up WAY over his head and tried to part it out. I think he lost a small fortune in the end.
My friends S1 RB25 RHD hits the clutch master cylinder too. I'll tell him to look out for another kind since he had the mounts shimed to tilt the motor a lil bit so it would clear.jdms13rhd wrote:I just threw in a NEO6 RB25 into my S13 Silvia with greddy mani. It does clear the bread master. There are 2 kinds of break master cyl's on S13's though. There is a kind with the chamber all in the same piece and there is another kind with a shorter snout with seperated canister. It will fit no problem at all with the cyl with the seperate chamber. I also got a S13 Silvia convertible that I threw in a SR20 with the Greddy intake and it had the long snout with the canister on top but all I did was throw a few washers under the engine mount and I cut off the bleeder nipple on the master cyl and tiged the little hole and its damn close but still not enough torque to hit it. Both ways work well. Here are some pictures of the RB25 in the Silvia and the SR20 in the silvia and picture of the nipple cut off the cyl.
Hope this helps.
BTW changing to RHD is a bit of work. Ive never seen anyone do it. Keep me posted. You should add me to your MSN messanger if you got it!!!
this is without cuting the nipple or raising the engine mount.
that's the worthless post i've ever seen.matt_calgary wrote:Just for your information, a skyline (which was never a LHD so custom stuff but still) Skyline Shop charges between 10k-15k plus 2 months for a RHD - LHD. If you were gonna get someone else to do it........move to Canada and get a RHD 180sx or silvia, haha it'll be cheaper but colder...!
thanks I aim to pleaseBoostsFed wrote:that's the worthless post i've ever seen.
anyhow, from the look of the picture above, unless you have solid mounts, otherwise engine movement under high torque will break that mstr cylinder.
