rb26 running without c.a.s.
makgf
hi, just bought a 95 240 with rb26 swap already done(i know i should've done the swap myself but the price was too hard to turn down), but any ways i noticed that there is no cas installed. it seems to run fine but i was wondering do i need to put a cas on it? thanks
Shocker
Car: 89 240sxHB rb26/30
what? thats not possible unless it has a trigger wheel with an aftermarket ECU. otherwise it has NO way in knowing its rpm, therefore no injectors or spark plugs would be fired. CAS is on the cam gear cover exhaust side.
Joe
makgf wrote:hi, just bought a 95 240 with rb26 swap already done(i know i should've done the swap myself but the price was too hard to turn down), but any ways i noticed that there is no cas installed. it seems to run fine but i was wondering do i need to put a cas on it? thanks
do you know what a cas is?
QuickerThanU
Car: 98,95,94,89 Nissan 240sx
LOL. Wtf.....
makgf
yup, i know what the cas is. it is an aftermarket ecu and it seems to run fine. i was just wondering if anyone has heard of this.
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
CAS = crank angle sensor. Might help if you knew what you were talking about. the CAS is in the front of your engine. I connects to the cam.
gawdzilla
Car: none
look at your crank pulley and look for a trigger wheel attached to it and an external pickup. thats your aftermarket CAS (crank angle sensor), so no you don't need the factory CAS (cam angle sensor)
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
I'll beat Carl to it this time, "what in the water?"
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
Can we get some pictures of what your talking about? That will keep us all on the same page here.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Shocker and gawdzilla have it pinned down.
StricNyne
ya my haltech has this option with a magnet or some **** sux cuz i need a cas PLUG with pigtail to wire mine in....
