qwertyz »
https://forums.nicoclub.com/qwertyz-u74424.html
Fri Feb 12, 2010 2:04 pm
okas per o2 sensor idle under 1.0v (.54-.93) create vacuum leak and fix it jumps to 1.4 vwhich tells me that both of my o2 are reading(dont have a scope at home cant realy see how fast they are switching, and i cant hook up to 14 pin connector for some reason no communication with ecu, and yes everything is connected)
as per mafs idle 1.2v as rpm raises voltage raises 2000rpm abou 1.8, 1.9vwhich tells me those are working fine also
So NOW I AM EVEN MORE CONFUSED
